Reposition front panel controls based on window size
I have a program that will be deployed on several different systems with varying resolutions and sizes.  What I want to know is if there is a way to reposition Front Panel objects relative to the window size automatically?
(2,670 Views)
You can search the forum, many topics are discussed on this,
one way for doing this would be  in VI properties--> window size.
mark both the option it will solve the problem to an extend.
To avoid any further problem, you should develop your application
on high resolution screen.
regards
(2,649 Views)
