Request Data from an Internet Site
Hi
i am trying to request a service from a website but i dont know which VI i should use.
I have to request the data in the address of the site itself and i am expexting data in the  xml format.
How should i proceed with it?
Somil Gautam
Think Weird
Message 1 of 8
(4,441 Views)
If the service you describe is a web service, then you can use the Import Web Service function in LabVIEW to read the data and view it as a LabVIEW data type (cluster, array, etc...)
If it is NOT a standard web service, the quickest solution would probably be to use the DataSocket protocol to retrieve the data. You would need to parse the XML yourself...
Message Edited by Phillip Brooks on 11-16-2009 07:18 AM
Message 2 of 8
(4,424 Views)
It might be as easy as reading the website's page? In the data, the address is echoed, and you can parse out the information you need? Just a guess. The attached VI will read a web page.
Richard
Message 3 of 8
(4,405 Views)
Here is another possible soultion
http://zone.ni.com/devzone/cda/epd/p/id/2743.
It has code to get the HTML code from a URL.
Once you have this, all you need to do is parse this code (String) for the data of interest
=== Engineer Ambiguously ===
Message 4 of 8
(4,377 Views)
Thanks all for the reply. Smiley Happy
This is the site from which i am trying to get the data. The input is in the form of an application id and address and in return i am going to get the coordinates (latitude & longitude) of the place.
There are many of toolkits in labVIEW for accessing internet. But i dont know from where should i start
Somil Gautam
Think Weird
Message 5 of 8
(4,349 Views)
The solution suggested by Broken Arrow seems to be perfect for you.
You can use the same one for your application.
Message 6 of 8
(4,272 Views)
I got it working with the example from the Yahoo web page. LV Version 2009f2.
1. The solution by BrokenArrow gives error 42 from the DataSocket Read.
2. The solution from the NI site is working with a little change. You have to set the property of IHTMLElement to OuterText. You will get the XML in the indiactor HTML Source Code.
Once you have the XML you can either parse the string by yourself or use the JKI EasyXML toolkit.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 7 of 8
(4,263 Views)
Thanks all for your contribution towards the thread.
I got the solution from the NI itself.
There is an example  at this link
Somil Gautam
Think Weird
Message 8 of 8
(4,207 Views)
