Request for copy of myRIO FPGA Example VI: Customized FPGA Signal Generator
I was wondering if someone could send me a copy of the "Customized FPGA Signal Generator Example" myRIO FPGA example project. I recently saved changes to it, but I'd prefer to have the original version.
- Best regards
(1,326 Views)
I take it you opened a LabVIEW Example and didn't immediately do a "Save As" (on the Project), choosing "Duplicate .lvproj file and contents", closing the Example, and opening the Copy (which you can safely modify, "ruin", but still have the original to "try again".
You should be able to restore things by reinstalling the myRIO Toolkit.  Open NIPM, and look for the two LabVIEW myRIO Toolkit entries.  Select them and try a Repair, which may work (I rarely do "Repairs", but tend to do "Complete Removal/Reinstall", which is probably "overkill" in this situation).  This should replace the myRIO examples for you.
Bob Schor
(1,298 Views)
Hello Mr. Schor,
Yes, that is exactly what I did with the example.
Thank you for the tip about the myRIO Toolkit Repair method. I will try that later today.
- Best regards
(1,251 Views)
