Require additional installers?
Since you are building a LabVIEW exe, the development license is irrelevant. There is no limit to the number of exe's you can deploy and no extra license is required. For Vision module, you need a new, separate license for each installation. You cannot use your existing Vision license.
Message 11 of 15
(1,386 Views)
Ok thank you for clarifying this for me, thisis very much appreciated.
damien
Message 12 of 15
(1,375 Views)
Hi Dennis, i have deployed the installation onto the monitor but there is no executable file contained within the folder where do you run the code?
Damien
Message 13 of 15
(1,360 Views)
What do you mean by 'monitor'? I don't know what you copied and where you copied it to. Did you click the 'Explore' button as previously mentioned? You should see a 'Volume' folder with a couple of folders along with a setup.exe. If you did not copy this folder, then you copied the wrong one. If this folder does not exist, your build of the installer was incorrect.
Message 14 of 15
(1,346 Views)
I forgot to copy over the executable file i had the setup.exe so it is installed ok now thank you
Damien
Message 15 of 15
(1,342 Views)
