Required Setup to learn templates geometric matching
Dear all,
I am writing a little VI to learn templates for geometric matching and avoid the need to use the Vision Assistant.
I have a general doubt:
-when learning a template is it necessary to specify geometric ranges such as expected SCALE and ROTATION of the searched matches? Or are these parameters just considered during the mathcing but not during learning?
Esteban
(2,834 Views)
Hey Esteban,
could you please post a small snippet of the VI which you use?
I'm not shure if there is only one geometric matching template function which provides this parameters.
Regards, Stephan
(2,795 Views)
