Required help with writing to a file.. urgent plz help
Hello Everyone,
                         I am using the following code to write data to a particular file..
I have 2 wfms, pressure and torque, the pressure is a simple one...
THe torque is bit complex, the operator has to press the "Start/Stop Torque DAQ" button and then select a filename... Next, he has to press the "Run/Stop Test"
button to finish 1 set of test and then write to the next available file name without pressing anything else...
I tried connecting an OR gate to the enable/reset ports, but it didn't work... Can anyone please suggest me how to do this??
Now on LabVIEW 10.0 on Win7
(3,463 Views)
Well, your Express VI's are set to Append to file as opposed to Use next available filename.
(PS.  You only need one punctuation mark to end sentences.)
(3,452 Views)
    i changed it to Use next available file name, but still it doesn't work
(3,444 Views)
Ravens Fan,
                  I simply connected a boolean control to the enable/disable port of the write to measurement VI, and kept the setting as USE NEXT AVAILABLE FILE NAME, but still, it kept on writing to the same file...
I read the help, and it said that the reset should be true to acheive this, how should i proceed? Please help
(3,439 Views)
Hh Crack Jack,
Try this...
<<Kudos are welcome>>
(3,424 Views)
Electro SAM,
                    Did it work for you?? i tried it... but it kept on appending the same file...
I simply have a analog read, write to measurement file ... everything in a while loop
If it worked for you, can you please upload your VI?
(3,402 Views)
Does anyone know about this yet?
(3,389 Views)
