Required input Bug
When switching an Indicator connected to the Connector Pane to "Control", the new connected Control is not flagged as "Required", even if this is the default option.
Tested in LV 2013 SP1 64 bits
Message 1 of 9
(5,464 Views)
If the indicator was not listed as required, why would changing it to a control suddenly make it required?  It is not a new connector being made, you are just changing the direction of an existing connector.
Message 2 of 9
(5,450 Views)
That's one point of view.
Another is: I deleted an output (which we cannot -yet- flag as required) and I created a new input.
Hence I'd like the rule for new input to apply.
Message 3 of 9
(5,401 Views)
In most of the cases you will rewire the new control to the connector pane, if the indicator was wired, as usual, on the right side of the connector pane. In this case the rule will apply.
Message 4 of 9
(5,375 Views)
Why would an output be required?  The subVI can function perfectly without any outputs being read.  Have you seen somewhere that claims they're adding the option to make outputs required?
Message 5 of 9
(5,361 Views)
No.  Outputs cannot be set to be required at this point of time.  X's message as the "yet" hyperlinked to an idea on the idea exchange discussing the possibility of making that an option.  See http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-required-outputs-in-VIs/idi-p/1899325
Message 6 of 9
(5,357 Views)
In the case that triggered this report, I had copied an Indicator from another VI and connected it "to the left" of the connector pane. I noticed the spaghetti plate of wires in the Help window and then changed the Indicator into a Control.
Maybe that clarifies why the lack of conversion to a "Required" input struck me as, if not a bug, a possible departure from the expectation of a fringe population (of which I might well be the only representative).
Message 7 of 9
(5,352 Views)
I would say that, in the technical sense, it was expected behavior.  The default trigger, I imagine, is the wiring of the connector; therefore, the default was applied when you wired the connector as an output.  Changing the indicator to a control didn't trigger it because you didn't rewire.
Now whether or not this is a LOGICAL expected behavior I think is open to debate.  And I have no idea how easy it would be to fix.  I mean the fix is probably easy; chasing down all the ramifications of the fix may not be.
Bill
CLD
(Mid-Level minion.)
Message 8 of 9
(5,337 Views)
I would say this is expected, sorry.
Also for an interesting read required outputs is sorta a thing, or at least a bug once existed that allowed it.
http://lavag.org/topic/6271-whats-wrong-with-this-picture/
Sorry so much LAVA 1.0 content was lost but I think it is still worth a quick read.
XNodes do allow to visually look like an output is required, but functionaly it doesn't need to be.
Message 9 of 9
(5,292 Views)
