Required: read from spreadsheet csv of 14 columns into Waveform chart with stacked plots
Hello there. I cannot seem to plot my waveform chart into stacked plots and the chart is somehow incorrectly put. Can anyone help me with it or point out which I should change?
Message 1 of 9
(4,616 Views)
Hi ping²,
don't use ExpressVIs!
The context help of the chart explains how to provide data!
Why don't you wire your 2D array directly to the chart? (Maybe all you need is an additional TransposeArray function!)
Message 2 of 9
(4,607 Views)
Thanks for your response. I have removed all functions in the middle and replace it with transpose. However the chart does not response to my csv file attached. Below is the result. My expected outcome would be like the graph attached below.
I do have done the graph in xy graph, but I needed result to be stacked.
Message 3 of 9
(4,599 Views)
Hi ping²,
you need to enable the stacking behaviour at edit time in the chart properties…
Did you?
It works for me:
That's the problem when people only attach images: we cannot examine their code nor can we debug those images!
Message 4 of 9
(4,585 Views)
Below is what I got so far. I can't seem to get my csv data to corresponds to the waveform chart.
Message 5 of 9
(4,579 Views)
Hi ping²,
it works for me:
- You should enable autoscaling of the x axis.
- As I already mentioned: don't use ExpressVIs for this simple task!
Message 6 of 9
(4,564 Views)
Thanks, I'm almost there. The result outcome you generate is exactly my aim. However I still cannot get that specific result.
Message 7 of 9
(4,560 Views)
Accepted by pingping12
Hi ping²,
I repeat a sentence of my last message:
You should enable autoscaling of the X axis.
Message 8 of 9
(4,554 Views)
Great!! Got it! Many thanks!
Message 9 of 9
(4,545 Views)
