Requirement of setting logic high to be +3.3V for PCI-6509 (CMOS compatible)
Hi, I have requirement to set logic level high for Digital Output to be +3.3V using PCI-6509 (CMOS compatible)for my system interfacing. Can it be programmed? Is this related with 3.3V LED on the PCI-6509? or related with 5V or +3.3V PCI bus, as I am using Industrial PC, not sure about the PCI bus voltages .. Thanks. ashish
(2,995 Views)
Ashish,
No, the NI 6509 does not have selectable voltage levels. However, the following KnowledgeBase does offer a solution:
KnowledgeBase: 3.3 Volt TTL from Digital Products
Moreover, the NI 654x digital I/O devices do have selectable voltage levels. Below, I have included a link to the appropriate product page:
NI 654x Product Page
Good luck with your application.
Spencer S.
(2,994 Views)
