Requirement to work in Labview real time.
hi,
   My requirement is to develop a tool in Labview real time module. My doubt is can i use the Dynamic link library (dll's) of a third party's hardware(this could be a driver of may be an AFDX or an RS232 interface) in labview real time? Can anyone tell me the significant changes in Labview and Labview Real time systems?
Jay
(2,372 Views)
Hi Jay,
If you want to check to see if a .dll is execuatble in LabVIEW Real-Time, there is a tool available with this document that will allow you to check. There are different reasons why a .dll might not be able to run in Real-Time, but some .dll's may be associated with some Windows functionality that is not available on a Real-Time target system.
The major differences between LabVIEW and LabVIEW Real-Time include the fact that Real-Time VIs will probably have timing in the code to increase the determinism of the system, and the VI can run on a remote target. For more introductory information on LabVIEW Real-Time, see document here.
I hope this information is helpful for you.
Stephen S.
Applications Engineering
(2,323 Views)
