Requirements Gateway: partial coverage
Hello community,
Before buying the NI Requirements Gateway license, we need to resolve a technical issue. Hereafter, the problematic:
A requirement of an upstream document is partially covered (20%) by a requirement of downstream document and partially covered (20%) by another requirement of the same downstream document (*.docx). I know that if I use a marco-requirement, the requirement of the upstream document will be covered at 100% only if the two requirements of the macro-requirement are covered. But our problem is that we can't use the macro-requirement because the requirements are not in the same chapter of the document. That's why we have thought to indicate a percentage of coverage. Is it possible in NI Requirements Gateway ?
thanks in advance for your help 🙂 !
Joris
SA Sunna Design France
Message 1 of 1
(2,268 Views)
