Requirements Gateway project programmatically access
Dear LabVIEW community!
Is there is some way to access data in Requirements Gateway project programatically, from LabVIEW? To get, for example, IDs of requirements in the proper format (like one can do in the Requirements Gateway itself - right-click on the requirement, and select Copy For -> LabVIEW Description Reference)?
Thanks in advance!
(3,406 Views)
Accepted by topic author kosist90
Unfortunately, accessing data from Requirements Gateway in LabVIEW is not possible at this time.
Jonathan R.
(3,312 Views)
