Hi all,
I am currently trying to resample x/y-data. In the waveform utilities, there is a polymorphic routine that is able to perform resampling on pairs of x and y arrays. So far, that's fine.
However, when using the waveform version of the polymorphic vi, I can set i.e. FIR filtering and the corresponding parameters. When using the x/y-array-version of the vi, I can set the interpolation mode to FIR, but cannot set its parameters. The resulting data also looks like linear interpolation.
Is there anyone around with experience in this field?
Matthias
