Rescan the user.lib folder w/o re-starting LabVIEW?
Does anyone know if there is a way to do this so that the tool palettes are refreshed if I place a new VI in my user.lib folder?
Thanks!
I'm in LabVIEW 2009 SP1
(3,071 Views)
Accepted by topic author hecmar.arreola
There's an Application class method which refreshes the palettes. I think it's available publicly, but if not, you should be able to access it by installing the scripting API.
___________________
Try to take over the world!
(3,061 Views)
I found it, thanks.
Not sure if it requires scripting or not.  I had already installed scripting so I'm not sure...
(3,047 Views)
In LV2009+ the property/invoke node turns baby blue if it requires scripting to be installed.
(3,044 Views)
There is an item in the application palette that will activate this function, it's called refresh palettes:
Ton
My LabVIEW Ideas
(3,030 Views)
