Reserve memory for array of pointers to structure (existing solution upgrade)
Hello NI developers!
After solving the problem in http://forums.ni.com/ni/board/message?board.id=170&message.id=365612#M365612   topic. This solution works. What left unsolved - I should assign address to a pointer each time: LV_array = (*((**in_array).Strings[*count])); by this way.
To create a well readable and simple program code I wanted to move a pointer like LV_array++;
Using  LV_array = (*((**in_array).Strings[*count])); I assign a pointer to the Strings[*count] element, not to the whole array. So my pointer points to one element, and if I do LV_array++; I get an extra "space" character
in the string indicator.
So I guess I should use something like LV_array = malloc(sizeof(LStr)*(*count+1)) ?
How then to assign reserved pointers to the whole array?
Is is this a good solution: reserving memory for array of pointers to struct and then moving pointer like LV_array++, or assigning  each time LV_array = (*((**in_array).Strings[*count])) ?
 Thanks in advance.
Message Edited by ACiDuser on 11-03-2008 02:58 AM
(3,878 Views)
I also wanted to know about the structure from extcode.h :
typedef struct {
    int32    cnt;        /* number of bytes that follow */
    uChar    str[1];        /* cnt bytes */
    } LStr, *LStrPtr, **LStrHandle;
 In what cases I should use each type LStr, *LStrPtr, **LStrHandle ??
(3,854 Views)
ACiDuser-
             I am not a C Programmer but I am going to try to help out a little bit. What exactly are you trying to use LabVIEW for? (signal conditioning, DAQ, etc.) And what sort of errors are you getting now? There is this website (http://zone.ni.com/devzone/cda/epd/p/id/1288) that provides some really good C help that you might find useful. Thanks!!
(3,820 Views)
Hello!
I want to use LabView for DAQ. My DLL works with a PCI-E driver. Inside DLL there are many function, which return messages with a printf(" text info / some stuff here ")
Certainly, If I compile my application as an .EXE, I see those messages in Windows console. If I compile application as .DLL and use LabView as user interface.
I need to use something like Array of String to display those error messages.
The error messages are different:
printf("VIRTEX5_DMAOpen: Failed allocating memory for VIRTEX5 DMA ""struct");
 and etc.
 By looking at this Array of Strings structures, which is automatically generated by LabView:
typedef struct {
     int32 dimSize;
     LStrHandle Strings[1];
} LVStringArray;
typedef LVStringArray **LVStrArrayHdl;
 we see that Strings element - is an array of elemets with type  LStrHandle
Looking in LabView\cintools\extcode.h we find this type defined like this:
typedef struct {
 LStrHandle seems to be an array of pointers to array of structures (or something else, I might be wrong, cause It's pritty tricky code and a lot of "*" make mess in my head)
 So this structures chain looks like this:
            LVStrArrayHdl in_array    (suppose to be an array of pointers to array of structures of type LVStringArray)
                 LVStringArray                                    (structure)
        int32 dimSize      LStrHandle Strings[1]        (suppose to be an array of pointers to array of structures of type  LStrHandle)
    (contains number         /                \
    of Strings in our      int32 cnt          uChar str[1]
    Array)               (contains number    (is array of type
                          of characters in    unsigned char,
                          current string)     actually it is a string
If in_array is declared in function parameter list like this:   _declspec(dllexport) void WhateverFunction( LVStrArrayHdl in_array );
 Then to create a pointer to string I do this:
    int32 *LV_StrNum = 0 //Set a number of String
    LStr *LV_array;      //Set a type of pointer.
NumericArrayResize(uPtr, 1L,(UHandle*)&(in_array), (*LV_StrNum)+1 ); //Resizing array
(*in_array)->Strings[*LV_StrNum] = (LStrHandle)(DSNewHandle(sizeof(int32) + StringLen*sizeof(uChar))); //Allocating Handle for current string
LV_array = *((*in_array)->Strings[*LV_StrNum]);  //Assign address to a pointer
//Now we can use simply  LV_array ->
      LV_array->cnt = StringLen;        //Set a length of current string
             sprintf(LV_array->str, LocalStr); // Write from local buffer to current String
But doing in such way - requires each time increase *LV_StrNum and after that assing pointer again:
  ++*LV_StrNum;
Now we are on the next line.
But the problem is - to assign LV_array pointer to Strings[...] so that we
could simply switch on the next line like:
   LV_array++;
and then perform:
 I think that I need somehow to allocate memory for *LV_array with help of malloc, but did not reach a working solution yet.
There could be another possible solutions. For example, if it is possible, - running this DLL in LabView with a console in the background, and copy messages
from console to LabView. So that way I could use just ordinary "Printf" function.
But I've spent a lot of time with those arrays and want to solve problem with this pointer.
(3,795 Views)
Hi ACiDuser,
      FYI: In this thread, Wiebe mentions "getting an array of pointers to
string elements in a string array" - not exactly what you requested, but his code may be instructive!
Cheers.
Message Edited by tbd on 11-04-2008 08:19 PM
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,749 Views)
ACIDuser-
         Were you able to find a solution in tbd's thread? Just checking 🙂
(3,705 Views)
Hi!
No, but I seemed to solve this problem myself. And this seemed not simplified my code much 🙂
Better would be to make something like this:
LV_array = in_array[i]->Strings[i];
But this doesn't work correctly.
Message Edited by ACiDuser on 11-10-2008 03:02 AM
(3,672 Views)
