Reset String Control Box Property Node Every Time VI Runs
How do I reset property node states (In particular, Text.BGColor) for string control boxes every time VI runs ? I found that once the color of a property node changes during the program, it does not change back for the next run.
Regards
FLiu
(3,524 Views)
You need to set it again at the beginning of your VI.
(3,515 Views)
If your VI is a state machine, simply put property nodes to set the values the way you want them in the Initialize state. You could also reset them in a Shutdown state just before the VI stops.
If you do not have a state machine architecture, it might be worth considering. Otherwise you will need to find a place for those property nodes where the dataflow will cause them to run at the very beginning of the program.
Lynn
(3,512 Views)
