Reset XY Graph on Button Press Fully
I found another thread regarding this problem and the subtraction seems to be the only way to fix this. I will see how I can implement this because the value needs to be subtracted continuously after the Reset button was pressed. And when I press it again the subtracted value needs to be adjusted.
If you have a thought how this would work easily i would appreciate the share.
thank you for the amazing help! I really appreciate this all. Thanks for doing this for this community this is not a matter of course.
Message 21 of 24
(403 Views)
Accepted by topic author Julsbng
A subtraction is trivial. Just keep the reference in a shift register as already explained and update it if needed.
Message 22 of 24
(397 Views)
Okay I will try this.
Message 23 of 24
(378 Views)
Everything is working perfectly now. Thank you very much. for your help!
Message 24 of 24
(346 Views)
