Reset variable value after each execution
@billko  escreveu:
Sorry for not getting back to you.  Are you able to save it as previous?  I only have LV 2016.  😞
Yes, im attaching the lib too.
When run normally, "event index" should always return 89, but if you run it continuously, a crescent value is returned. And that s the behavior I am having on TestStand suite, each step that call this VI returns an incremented value.
Message 11 of 16
(1,616 Views)
Thank you.  Let me chew on this.
Bill
CLD
(Mid-Level minion.)
Message 12 of 16
(1,592 Views)
I know TestStand "pre-loads" your VIs.  I think it might be related to the fact that your Vi stays in memory, like it grabs the equivalent of a new reference each time because of that.  Some things point away from that conclusion, though, like it should work the same way if VI was open but not running.  I believe that "continuous run" is just the equivalent of clicking the run button as fast as possible.
If you're calling something "homegrown", it might be worth thinking about thread execution...
Of course there's always the possibility that the dll isn't quite working correctly.
Sorry, that's all I have.
Bill
CLD
(Mid-Level minion.)
Message 13 of 16
(1,571 Views)
@billko  escreveu:
It's alright billko, I really appreciate your effort. I ve found a way to overcome this problem in TestStand, I ll be posting here just for information, even though, I am pretty sure that this can be fixed on LV.
https://forums.ni.com/t5/NI-TestStand/Why-is-my-VI-still-running-after-my-teststand-sequence-has/td-...
if anyone could still help, i d be grateful.
Message 14 of 16
(1,566 Views)
@enzofurlan wrote:
@billko  escreveu:
Great!  I'm super-curious - and it could lead someone to a solution and not a workaround.  🙂
Bill
CLD
(Mid-Level minion.)
Message 15 of 16
(1,557 Views)
Still couldn't find an answer inside labview suite, could someone help? Smiley Sad
Message 16 of 16
(1,525 Views)
