Resetting Array
Small tip: Wire the full error wire to the case instead of the error-boolean, then the case structure will change color and it'll be alot more pedagogical to look at.
There's also no need to use a separate wire for the Initialize case, the shift registered one will work just fine.
Why a wait when you have a timeout for the queue?
Hmm, each time you press a button you save the time and a random number, and  write it to a file every so often? Why not a simple event structure that saves the values when pressed?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 32
(2,376 Views)
If I were to save the time and random number within the event structure, then the process would not continue unless it is in the timeout case. Essentially, I created an extended timeout case utilizing queues. Therefore, each case would be condensed and the data could visually flow better. (maybe I was wrong).
"There's also no need to use a separate wire for the Initialize case, the shift registered one will work just fine."
What do you mean? (graphic?)
CLD Certified 2014
Message 22 of 32
(2,367 Views)
/YInit.png
Qestit Systems
Message 23 of 32
(2,354 Views)
If the init case should also be functional at a later time, the solution on the right will not work.
Message 24 of 32
(2,342 Views)
Quite right, then you should put the constant inside the Init case (which is slightly prettier to me anyways).
/Y
Qestit Systems
Message 25 of 32
(2,329 Views)
Since there are so many constants, another line looks better and more compact. Adding a bunch of constants inside the loop could increase the size. Also if more constants were to be added, I would only need to update them in one cluster.
CLD Certified 2014
Message 26 of 32
(2,327 Views)
I have been able to find the threshold times and #s but I only want the first time and #. It keeps updating the 2D array for each reading.
Also the threshold times #s should still reset like the initial #s do.
Thanks for all of your help.
CLD Certified 2014
Message 27 of 32
(2,309 Views)
This is what I was trying to accomplish in my Resetting Vi. I am having trouble integrating this into the Resetting Vi.
CLD Certified 2014
Message 28 of 32
(2,282 Views)
Here is a more complex version. I am hoping to incorporate the same outputs in the Resetting Vi. I am not sure how to do so. I feel like a for loop around the whole thing with an array of constants would work.
CLD Certified 2014
Message 29 of 32
(2,273 Views)
I was able to implement the threshold into the resetting Vi. I do not know why the value keeps going to zero.
CLD Certified 2014
Message 30 of 32
(2,251 Views)
