Resetting Control Values
I am doing some motion control programming and I am trying to figure out how to reset a control to zero in the programing enviroment. I have a slider that controls velocity of one axis and then I have a mode where the axis goes to some preset positions. When the program comes out of position mode I want to reset the slider to zero so the axis is not moving when I go back to the interactive mode.
Perry
(2,890 Views)
Have you tried using a Property Node, linking to the Control in question and using the Value property (in Write) to see the slider?
(2,889 Views)
