Resetting XY graph plot names in LABVIEW
I have code that changes the plot names. I would like to add a "Clear All" button that resets the plot names to their original Plot 0, Plot 1 . . . names. "plots" is the number of plots that have been renamed so that the for loop can reset the names of those corresponding plots. My problem is that Plot 0 is not renaming plot 0, it is renaming the last plot whose name was changed, and then plot 0 is renamed to Plot 1, plot 1 becomes Plot 2 and so on.
This is the relevant cases. Case 1 reinitializes the graph to default, Case 3 sets Clear All to false and resets the plot variable.
Here is an example of plots being renamed:
Here is what I get when I click "Clear All"
I have tried highlight execution and it looks like it should be renaming plot 0 when i=0 but for some reason that is not occurring. Thank you all in advance!
(2,229 Views)
Accepted by topic author cathborisova
Set the active plot before setting the plot name (move it higher up in the property node)
(2,222 Views)
