Resetting a graph
Hello
I've been trying to reset a graph, but for some reason previous values keep popping up.
I tried setting value to empty, reinitializing to default and several other things, but every time i run the graphing after "reinitializing" the previous run values come back.
What am i missing here?
(1,548 Views)
Accepted by topic author AeroSoul
Have you tried connecting the merged signals to graph instead of processing?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,534 Views)
I guess that works. Just removing the Configure Collector express VI works, but i don't understand why?
That VI (should) only sets the maximum number of samples.
(1,505 Views)
Hi Soul,
You set the number of samples right at the FOR loop "N" terminal.
Why do you need any ExpressVIs in your image???
(1,499 Views)
