Resetting the timer of "elapsed time express VI" in a case structure.
I am using a case structure. For the event to be TRUE, the program should perform 3 Boolean operations TRUE condition I have made use of 3 elapsed time VIs. The 3 Boolean conditions have to executed in 2,5,8 seconds respectively. After 2 seconds, Boolean 1 should turn ON. After 5 seconds Boolean 1 should turn OFF and Boolean 2 should turn ON. After 8 seconds Boolean 2 should turn OFF and Boolean 3 should turn ON and must continue to remain ON unless the FALSE condition is executed.
During the FALSE condition, all 3 Boolean indicators must turn OFF and all 3 timers have to be reset.
While executing from TRUE to FALSE there is no problem,but while executing from FALSE to TRUE, the 3rd Boolean continues to remain in ON state rather than OFF state because the timer starts off from the point where it last was instead of resetting.
How do I correct this problem so that the timers start from 0 second everytime the TRUE case is executed?
(5,872 Views)
connect the bool (reset and output) onto a shift register...  Smiley Wink
(5,860 Views)
Please attach some simplified code. Your words are not sufficient to describe what you are actually doing.
(5,857 Views)
Accepted by topic author cricketfreak
hope this helps....if not, modify to your requirements
Spoiler
(5,838 Views)
i was not happy with the last code, so here is the revised one....slight logic change here Smiley Wink
Spoiler
(5,827 Views)
Thanks a lot for the help. It worked perfectly.Smiley Happy
(5,802 Views)
