Resistance to temperature conversion
I need to accept the resistance and convert that to temperature in Labview. Cn some one give me the formula.
Actualy I need to get the temperature below 73K. But my RTD (FP-RTD-122) has data configuration as 73k - 1123k and not below 73k.
So i hv to do this is the labview program by accepting the resistance (0-400 ohms) and convert to temperature.
Thanks in advance.
(4,306 Views)
What RTD device are you using?  That should get you started on what formula you need to use.
If the RTD has a range of 73 Kelvin to 1123 Kelvin, then you won't be able to measure under 73 Kelvin.  you will need a different RTD that can measure the range you are looking for.
Kenny
(4,286 Views)
Possible cross-post.
(4,279 Views)
Ok Sir, but cnt we get the resistance nd convert that to temperature. I wnt to knw hw 2 do that.
(4,259 Views)
Something is wrong with your keypoard 😉
The manual of the FP-RTD-122 claims that you can measure resistance in the 0-400 or 0-4000 Ohms range. If the resistance of your sensor is in this range, just open MAX and configure the module
RTFM http://digital.ni.com/manuals.nsf/websearch/BF61417EFEE4EFCE86256CEE00691C9F
If you only have R=f(T) and need T=f(R) you can use
a lookup table (with linear or cubic interpolation ..)
the polynominal fit  (from the table above) to get a close approximation (higher order will result in an error less than 10mK, far less than the Sensor or 2 wire read)
 or Newton interation or.... or....
Message Edited by Henrik Volkers on 06-28-2007 11:22 AM
Greetings from Germany
Henrik
LV since v3.1
(4,252 Views)
