Resize Array Up/Down Arrows
I noticed just now that if I try to customize an Enum control, I can freely resize the increment/decrement buttons.  However, this does not appear to be possible with the up/down arrows on the index display of an Array control.  Am I missing something?
Message 1 of 14
(7,945 Views)
The array index is a numeric control, so after editing the array and going into customize mode, select the index and goto Edit->Customize to customize the numeric.  Then you can resize the up/down increments.
Message Edited by Matthew Kelton on 12-17-2007 02:34 PM
Message 2 of 14
(7,942 Views)
I have always enjoyed the ideas in this thread.  http://forums.ni.com/ni/board/message?board.id=170&message.id=127096
You can customize the array container a lot.
Message 3 of 14
(7,927 Views)
I see!  So for some reason that's just not included in the right-click menu?
Message 4 of 14
(7,922 Views)
Yes, I don't know the reasoning behind it, or if it is an oversight.  There are several controls which have subcontrols which can be modified via the menu (the plots are probably the controls with the most).
Message 5 of 14
(7,917 Views)
Hi Matthew,
NI simply shut-down our ability to eidt a control while editing a control.
As mentioned in the afore cited thread, you first make your mods to the sub-control and save it to disk.
When you go back into the Control editor for the array, choose the reaplace option and choose your previously mentioned sub-control, in this case the array selector.
Watch your data types!
Ben
Message 6 of 14
(7,908 Views)
Ben,
Actually they didn't.  You can still edit a subcontrol by selecting the subcontrol and choosing the Edit->Customize menu item, which edits the subcontrol in a new window.  You can edit it, not save it and have LV replace the existing control.  What NI doesn't do for some unknown reaosn is give you the right-click context menu option of Advanced->Customize which would give you the same result as the Edit->Customize Control path.  So, you always have to keep in mind that just because the context menu is not there, it does not mean you cannot customize the control.
Message Edited by Matthew Kelton on 12-17-2007 06:15 PM
Message 7 of 14
(7,902 Views)
Thanks Matthew!
See i was try to help you out and it turns out you showed  me something I have been missing in about the last 5 releases!
Message 8 of 14
(7,871 Views)
I am with Ben, great catch there.
Message 9 of 14
(7,849 Views)
So, then, perhaps the "bug" is NI forgot to disable the Edit->Customize Control menu item instead of not providing the Advanced->Customize context menu item.  Of course, if they ever disabled this, I would be extremely unhappy haveing to save changes to a subcontrol in a one-off custom control.
Message 10 of 14
(7,838 Views)
