Resize Scroll bar in Table Control or Multicolumn ListBox
@ Ashish, I tried the solution to modify the ini file and it doesn't work.
You ahve any other solutions ?
Manu Mohan
Message 11 of 18
(2,286 Views)
@Aashish_M wrote:
Hey Anil,
Form speaking to R&D I found a work around. Try adding the INI token AutosizeScrollbar=FALSE in the LabVIEW.ini file within C:\Program Files\National Instruments\LabVIEW 2009\ folder.
Hopefully this works for you.
I am using LV8.5.1. Adding INI token as you mentioned doesn't work in this version. Please suggest me any other solutions.
Manu Mohan
Message 12 of 18
(2,284 Views)
Hi Manu,
This knowledge based article suggests a work around for older version of Labview
http://digital.ni.com/public.nsf/allkb/82C0B021A14F118D86257141004BA97E
Josh Brown
Message 13 of 18
(2,256 Views)
Hi Manu,
Josh Brown
Message 14 of 18
(2,256 Views)
@Josh B wrote:
Hi Manu,
Josh Brown
Thank you for your suggestion.
Though it is a solution, my customer don't want to loose the freedom of scrolling the bar on his touch screen. Boolean buttons doesn't support that. Is
there any other workaround to get me the complete functionality of scroll bar ?
Message 15 of 18
(2,252 Views)
Hey Manu,
Have you considered using xcontrols? Here is a developer zone article that discusses every thing about xcontrols from creating them to debugging them. Let me know if this works for you.
http://zone.ni.com/devzone/cda/tut/p/id/3198
Josh Brown
Message 16 of 18
(2,230 Views)
Hey,
bug still in LabVIEW 2013 f2.
Add this Key to your LabVIEW.ini
AutosizeScrollbar="False"
Should work.
nookie
CLA
Message 17 of 18
(1,988 Views)
and also this one:
autoResizeScrollbars=false
Message 18 of 18
(1,959 Views)
