Resize a check box
Does anyone know how to resize a check box in LabVIEW 7.1?
Paulo
Message 1 of 16
(6,755 Views)
I will guess that you are asking about the "dialog checkbox".
Right-click and select
Advanced>>>Customize...
Then switch into "blow torch" mode (see attached jpg).
You will then be able to change the size.
I hope this helps,
Ben
Message 2 of 16
(6,737 Views)
Hello ben,
after saving and reloading the check box returns to it's older small size...
Any hints?
Message 3 of 16
(6,731 Views)
Yes!
Those dialog controls are always tricky to modify.
So the correct answer should have been,
"sorry you can not do that but,..."
I have another approach that may help.
I customized a non-dialog checkbox by copying the images from the dialog version and pasted them into the non-dialog version.
Since it is not a dialog type, LV does not "fix" it for me when I re-open.
I hope the attached is more helpful than my previous image.
Ben
Message 4 of 16
(6,728 Views)
One more time!
This time with the false image replaced.
This just demonstrates the idea.
Be carefull about the size of and shape of the controls when you copy the images and replace the old.
I think I need some coffee.
Ben
Message 5 of 16
(6,726 Views)
Thanks for your help, but for some reason I'm not succeeding to do it.
What tool do you use to resize it after selecting the blow torch?
I can only resize the box arround it...
See picture attached.
Paulo
Message 6 of 16
(6,718 Views)
It looks like you are just grabing the wrong corner.
See attached for step by step illustration.
Ben
Message 7 of 16
(6,702 Views)
Hi Ben,
I'm very sorry and very thankfull, but for some reason I'm not succeeding to follow you, I just can not drag the corners off the white box!!!!!
Can you please save your control and send it?
Thanks a lot,
Paulo
Message 8 of 16
(6,700 Views)
Message 9 of 16
(6,694 Views)
Hi Ben,
Sorry, it is small as the one from the pallete!
I must have some strange configuration that doesn't allow me to do this.
Once more thank you very much for your help.
Message 10 of 16
(6,535 Views)
