Resize system checkbox and system radio buttons
Is it possible to resize the system checkbox and system radio buttons. If we right click either of them and go to properties, the size controls are disabled. Wonder if this is achievable.
Also I noticed I could add the new radio buttons by right clicking it and choosing add new button. Is it possible to achieve this programattically.
Kind Regards
Austin
(9,934 Views)
You cannot customize any of the system contros but some of them you can do resize and increase the font size but no customization. You can add radio button by clicking the main contol (Not the individual boolean controls inside) and select add radio button its a kind of a cluster but the data type is Enumerated.
(9,925 Views)
Accepted by topic author K.Waris
As has been mentioned, system controls cannot be customized, because they depend on the windows theme. However, these are just booleans, so all you need to do is use a plain boolean and import the graphics you want into the true and false case. They can easily be made to look like a oversized checkbox. More details, especially regarding radiobuttons can be found here.
You could probably do it programmatically in edit mode using scripting. You cannot do it at run time.
To fill a radiobutton control with new booleans, you can simply drag new booleans inside it or even shift-drag an existing element to create a copy of it. Don't forget to change the labels to something intuitive.
(9,922 Views)
While you can't create new radio buttons are runtime, you can get the same behavior if you use an array of booleans and change the number of visible items.  You will, however, need to handle the "radio button" functionality yourself.  This is relatively easy using an event structure.  This would also be a good candidate for an XControl, if you think you might want to reuse it.
(9,886 Views)
