Resizeing 2D PICTURE image with transparent background
Hallo !
I need to resize several 2D PICTURE indicators showing images with transparent background. I would like tu use the "zoom Factor" property.
Unfortunately I have found that appling a Zoom factor other than 1 , the trasparent background (set using the mask in image components) is set back to the original color.
Is it  a bug or there is something worng in my programming?
Thanks in advance.
Luca Nitopi
(1,080 Views)
No, I don't see any troubles with transparent background and alpha:
Show your code, please.
(1,060 Views)
Hallo!
Thank you for your kind answer.
My problem is that I have to load images from PNG files with transparent background.
Using standard load function transparency information is lost
Using "create mask" function I can show images with transparency, but only with "zoom factor =1" :
Is there something wrong in loading files?
Thank you!
(1,006 Views)
you may have a look at:
https://forums.ni.com/t5/LabVIEW/Best-way-to-retrieve-mask-info-from-picture-also-Doom/m-p/4013618#M...
(991 Views)
Accepted by topic author Luca_Nitopi
You should pass alpha mask, the following snippet could be helpful for you:
seems to be OK:
(985 Views)
OK. Thanks!
(961 Views)
