Resizing IO-Controls Bug
Hi all
I just recently found that obviously some controls from the IO-palette do not resize correctly. This seems to be a bug, as not all of them resize incorrectly.
In the attached VI select all controls and select "Resize Object > Maximum Width". The width of the IO-controls is not incresed but the height.
LV-Version: 8.0
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,771 Views)
Hi Thomas,
I´m sorry for this behaviour. I´ve searched our internal Knowledgebases and found a correction order for the developers of LabVIEW. So, it´s a known behaviour. But I don´t know when it will be fixed.
Thanks for the help of improving our Products.
I rate your message with 5 stars! :0)
Best regards
Alexander Rudolph
NI Switzerland
(3,754 Views)
Hi Alex,
According to Philip Courtois, there should be a CAR# posted for this if this is indeed a bug.
Thank you,
Ben
(3,739 Views)
the CAR-ID I found to the topic is: 32QH75MQ
Best regards
Alex
NI Switzerland
(3,699 Views)
As Alex mentioned...
This was reported to R&D (# 32QH75MQ) for further investigation.
Thanks for the feedback!
Message Edited by Travis H. on 09-27-2006 02:47 PM
Travis H.
LabVIEW R&D
(3,622 Views)
