Resizing WaveFormChart
I'm trying to resize the chart to fit in a tab control that is already resizing to fit a window.  Problem is, I can resize the black square, I can move the legend, I can position the Chart "gray box"
I end up with:
How can I size the main box?
Message 1 of 8
(3,961 Views)
Try positioning your mouse where I put a red circle to resize the entire chart:
Message 2 of 8
(3,957 Views)
Sorry, programmatically
Message 3 of 8
(3,947 Views)
Your picture has too poor resolution to read.
You should be able to use the Plot Area:Size property to resize the entire chart.
Message 4 of 8
(3,925 Views)
If you click the picture and then full screen it you can see it very well.  I am using that property though.  Perhaps it's the order in which I'm applying them.
Message 5 of 8
(3,922 Views)
Eliminating the PlotBounds property in the middle seems to have fixed it.
Message 6 of 8
(3,919 Views)
Even if I open in a separate tab it's a very blurry 400 x 124 px image. Can you upload the actual VI?
Message 7 of 8
(3,917 Views)
Ok good to hear!
Message 8 of 8
(3,916 Views)
