Resizing labview window that has been converted
I just would if it is possible to resize a labview window once it has been converted to a different version. I have labview 7.1 and converted to 6.1 and I am trying to resize the window but it doesn't let me. Is there another way around this?
(2,536 Views)
You should be able to resize any vi even though it has been converted.  Go to the File Menu and select VI Properties.  Then select Window Size in the Catagory box.  Make sure that zeros are entered for the Minimum Panel Size, and that the "Set the Front Panel to the width and height of the entire screen" checkbox is unchecked.
- tbob
Inventor of the WORM Global
(2,531 Views)
