Resizing objects on the block diagram
Does anybody know of a way to batch-resize objects on the block diagram the same way that can be done on the front panel? For instance: often when I'm making parallel loops, I'd like for them to be the same size (or at least the same width). I instinctually reach for the "Resize Objects" pulldown menu only to be reminded that that feature exists only for the front panel. Has this been submitted as a feature suggestion by chance?
(4,197 Views)
You might be interested in this idea. I understand that it makes easier to maintain the Block diagram neat, but I am comfortable enough to clean my BD without that Re-size menu.
(4,189 Views)
You can search the Idea Exchange to see if the idea is already there.  I want to say it has been submitted, but I am not certain.
But you might want to have a look at the LabVIEW Shortcut Menu Plug-Ins and possibly develop your own to do this job.  I would like it myself.
(4,187 Views)
This is the first I've heard of this functionality. I'll have to check it out.
(4,133 Views)
