Resizing the Front Panel
I am trying to resize a front panel display that was originally developed on a larger monitor. When I try to resize the front panel under file>>>vi properties the front panel indicators, controls, objects, become somewhat jumbled and the font does not seem to adjust. Is there an easier was of downsizing a front panel display withour all of this mess?
(2,845 Views)
If you go to VI properties (ctrl-i) >> window size, you can set the VI to maintain proportions of windows for different monitor resolutions and you can set to scale all front panel objects as window resizes. The images will not be perfect due to rounding error but they will be close to the original.
Jeremy Braden
(2,845 Views)
