Resolution Issues with LabVIEW 2017 in Parallels Desktop
I'm running Windows 7 pro 64-Bit in a vm (in Parallels Desktop 12.2.1) on a MacBook Pro Retina (macOS Sierra 10.12.5, Late 2012, 15'').
Originally LabVIEW 2016, with TestStand 2016, Realtime, FPGA etc. was installed on the vm. Now I installed LabVIEW 2017, TestStand 2016 SP1, Realtime, FPGA etc. and LabVIEW NXG.
My problem now:
All newly installed versions have resolution issues. Means, they are running on full retina resolution., but the fonts seem to have the correct size. This makes hard to work with (See appendix). LabVIEW NXG has this issue only while starting LabVIEW and showing the splashscreen. LabVIEW 2016 still runs perfectly fine.
Any ideas?
Sascha Kirchdörfer
- Anytest Engineering GmbH
(3,416 Views)
Accepted by topic author skirchdoerfer
Solved it! I had to reinstall the parallels tool in windows. Now everthing's fine. So easy 😉
Sascha Kirchdörfer
(3,368 Views)
