06-12-2006 12:02 PM
06-13-2006 02:17 AM
06-13-2006 02:17 AM
06-13-2006 08:56 PM
06-14-2006 02:20 AM - edited 06-14-2006 02:20 AM
Uuhhh, you don't need to shout ![]()
What type of sensor (Pt100, NTC ???) are you using?
How is your setup (gain, exitation, connector block, ... )?
Just because you have a 10mK resolution in the calibration tool, that doesn't mean you can get this resolution with your setup.
If you use a Thermistor 0.06K sounds reasonable in respect to some exitation and gain settings.
Message Edited by Henrik Volkers on 06-14-2006 09:47 AM
