Resolve Fonts
This VI works fine in the IDE, but not in an executable.
Any suggestions would be appreciated (other than the obvious of manually copying the font specs from labview.ini to a custom app.ini).
(2,136 Views)
What does not work fine in an executable?
I created an executable (Application.exe) of your VI.
- if the entry 'appFont="Arial" 12' is in Application.ini the executable returns 'Arial' and '12'
- if appFont is not in Application.ini the executable returns an error 1520.
What do you want to achieve with your VI?
(2,080 Views)
I want it to work without having to manually copying the font specs from labview.ini to a custom app.ini.
(2,020 Views)
So do I.
I gave up years ago...
(2,006 Views)
There is a vi analyzer test to find all symbolic fonts. Replace each with a defined font. (Discussion leading to it).
(1,995 Views)
My use case was to parse a picture control string, to render it in a PDF.
However, "Application Font" doesn't mean anything if you don't know what the "Application Font" is.
And there is no way to query that.
(1,991 Views)
