Resolve issue with Duplicating Case Structure frames and Differencing
Multiple support engineers have told me that LabVIEW reuses some internal references if you duplicate a frame in a case structure and that this causes the LabVIEW diff tool to confuse and highlight different frames of a case structure when comparing two versions of code.
The support engineers recommend to always create a new case rather than copying an existing case to prevent this issue.   This seems to be a fundamental flaw with LabVIEW's "duplicate" mechanism - any copies etc of objects (case structure frame in this example)should be treated exactly the same as creating a new object
(589 Views)
This sound like it should be in the idea exchange forums.
Former Certified LabVIEW Developer (CLD)
(576 Views)
I've never heard of that, do you have any examples?
Qestit Systems
Certified-LabVIEW-Developer
(481 Views)
I think these support engineers need to deliver some more information.
I've been using LabVIEW for over 2 decades and I am not familiar with what they are saying.
What I DO know is that sometimes if you replace one dynamic event registration refnum with another one with different events, LabVIEW can make a bit of a mess of re-assigning the individual event cases to the eventy within the registration refnum. To get around this, we include a text in each case to highlight which event it's supposed to be handling just in case LabVIEW gets them mixed up.
(454 Views)
Can you explain why this is a problem?  Is it the diff tool or the workbench?  (Yeah, the "W" in LabVIEW is "Workbench")
Even if case duplication hinders YOUR workflow, in such a manner that a single tool's behavior is a showstopper,  what is wrong with the workaround of creating new cases?  How much code do you need to duplicate when creating a case?  The best answer is "none."   Do This or do That is the essence of cases within a structure.  This and That should be distinct or outside of the case structure, right?
What specifically is your workflow?  show example.
(439 Views)
