Resource conflict: PXI 1000B with NI PXI 8106 & NI 8420/2
Dear readers,
What:
I am using an embedded controller (PXI 8160) with a rs232-card (NI 8420/2) in a PXI-rack (PXI-1000B).
Problem:
At startup of the rack, i get the message: Resource conflict, PCI in slot 2    /     Bus: 0B , Dev: 0F, Function: 00. F1     / Press F1 to resume or Del to enter Setup.
If i continue after the conflict, i can see the 2 com-ports properly installled in my hardware manager .
After startup, when i look in the systemtab of eventviewer, i find an error. This one is also there when the 8420 is not plugged in.
"Boot-start or system-start drivers failed to load: nvatabus / nvraid" + "Source: service control manager". (see attachement)
What did i try:
If i remove the NI 8420 card, there is no problem.  If i keep the 8420 in the rack but in another slot, the problem stays but at a different slot.
Maybe there is something wrong in the bios settings, though i almost tried every setting including reset/ disable comport of the 8106/ ... .
Swapping the card did not work too.
I tried this 8420 in another rack (without an embedded controller) but there were no conflicts.
Formatting the embedded controller (windows xp and drivers)
I hope somebody can tell me more about this. Thanks in advance.
Steven
(3,065 Views)
Hi Stephen,
Thanks for the detailed post!
Im am out of the office at the moment, but I will endeavor to look into this tomorrow (16th Oct), if no one else gets in touch with you first.
Kind Regards,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,044 Views)
Thanks, it would be nice.
Meanwhile i started a post at the correct place in this forum (board PXI). I did not find how to move my post. So please continue there. (same Message Subject)
I did also a loopback test on all the com ports ( one from embedded controller and two from the NI 8420). Everything looks fine.
Steven
(3,032 Views)
Hey all,
You can find the duplicate post here .
Kindest Regards,
Wouter Van Hoof
Applications Engineering
NI Belgium
(2,980 Views)
