Respaceing Array of LED's
Guys,
Attached is a .vi that has a few arrays of LED's.  The problem is that the LED's on the front panel are way to close to each other that i'm not able to put text by them.  Is there anyways to respace the LED's.  Thanks.
(2,822 Views)
You can customize the LED by right clicking on it and selecting Advanced>Customize. In the control editor, click the little "wrench" symbol to change it to tweezers. There is a part of the control called the Boolean Glyph (Window>Show Parts Window). This is a part that surrounds the actual button and can be re-sized. Move the button to the center of the glygh and you can color the glyph transparent.
(2,803 Views)
