Response becomes sluggish after an extended run of the VI
I am using two cDAQ chassis to read therocouples and voltages.  There is not much user interaction on the Front Panel other than calling three sub VI's via "Hot Keys".   The program runs as expected at first, but after it has run for an extended period (ie, hours/days),  the update on the front panel, and the responsed to the "Hot Keys" becomese very sluggish.   I am suspecting a possible memory leak, but not sure where or how to track it down.   Any suggestions would be very much appreciatied.
(2,766 Views)
There is a great deal of talk about memory leak on discussion forum. Look at
http://forums.ni.com/ni/board/message?board.id=170&message.id=61610&query.id=149257#M61610
to see if it helps.
(2,759 Views)
I would definitely suggest searching ni.com for terms like "memory leak labview" to get some ideas.  One KnowledgeBase entry I found mentions the use of graphs and charts as a possible cause: Why Does My LabVIEW Application Use More System Resources the Longer it Executes?
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(2,740 Views)
