Ressource overmaping
  Dear,
For the project I uesd a compact rio 9002 with the NI9411 slot.
My question is about the seize of the ressource:
Is it a RAM seize problem or a the FPGA hard drive problem?
  Thank you in advance
Compilation failure:
Status: Compilation failed due to resource overmapping.
The FPGA VI does not fit on the FPGA target because the VI requires more resources
than are available.
Suggestions for eliminating the problem:
  * Reduce the amount of logic in the VI
  * Reduce the number of multiplications, FIFOs, and/or amount of memory on the block diagram
  * Change arbitration settings
  * Use Timed Loops instead of other loops
  * Use Timed Loops for resource-intensive sections of the block diagram that
    do not require any looping
  * Recompile
Number of Block RAMs:               64 out of      40  160%
Message Labview FPGA compile:
This mapped NCD file can be used to evaluate how the design's logic has been
   mapped into FPGA logic resources.  It can also be used to analyze
   preliminary, logic-level (pre-route) timing with one of the Xilinx static
   timing analysis tools (TRCE or Timing Analyzer).
Design Summary:
Number of errors:      1
Number of warnings:   73
Logic Utilization:
  Number of Slice Flip Flops:       1,782 out of  10,240   17%
  Number of 4 input LUTs:           2,902 out of  10,240   28%
Logic Distribution:
  Number of occupied Slices:        1,893 out of   5,120   36%
  Number of Slices containing only related logic:   1,893 out of   1,893  100%
  Number of Slices containing unrelated logic:          0 out of   1,893    0%
        *See NOTES below for an explanation of the effects of unrelated logic
Total Number 4 input LUTs:          3,106 out of  10,240   30%
  Number used as logic:             2,902
  Number used as a route-thru:        204
  Number of bonded IOBs:              149 out of     324   45%
    IOB Flip Flops:                    13
  Number of Block RAMs:               64 out of      40  160% (OVERMAPPED)
  Number of MULT18X18s:                 2 out of      40    5%
  Number of GCLKs:                      2 out of      16   12%
Total equivalent gate count for design:  4,238,602
Additional JTAG gate count for IOBs:  7,152
Peak Memory Usage:  175 MB
NOTES:
   Related logic is defined as being logic that shares connectivity - e.g. two
   LUTs are "related" if they share common inputs.  When assembling slices,
   Map gives priority to combine logic that is related.  Doing so results in
   the best timing performance.
   Unrelated logic shares no connectivity.  Map will only begin packing
   unrelated logic into a slice once 99% of the slices are occupied through
   related logic packing.
   Note that once logic distribution reaches the 99% level through related
   logic packing, this does not mean the device is completely utilized.
   Unrelated logic packing will then begin, continuing until all usable LUTs
   and FFs are occupied.  Depending on your timing budget, increased levels of
   unrelated logic packing may adversely affect the overall timing performance
   of your design.
Mapping completed.
See MAP report file "toplevel_gen_map.mrp" for details.
Problem encountered during the packing phase.
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
(3,098 Views)
Massif,
The error message you received is due to over mapping of your FPGA code.  What back plane are you using in your system. To remedy this problem you ether need to reduce the amount of code in your FPGA vi, or move to a back plane with a bigger FPGA.  This error is not related at all to the 9002, but rather the back plane (ie 9101, 9102, 9103 or 9104).  You may want to look at other resources about FPGA utilization.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(3,092 Views)
  Thank you StevenA
(3,063 Views)
