Restart VI Execution from SSH
It is possible to restart the execution of a VI inside a CRIO (CRIO-9067) from SSH, without 'reboot'ing the controller?
I can establish all SSH and FTP communication, I just need to know the service or program which controls the NI VI set as execution at reboot.
Thanks in advance.
(1,833 Views)
On NI Linux RT you can run this command to restart your startup app
/etc/init.d/nilvrt stop && /etc/init.d/nilvrt start
There are a number of threads discussing this, but it‘s still hard to find from search. Maybe adding some links and tags will Maike ist better.
Run startup.rtexe in linux from terminal
cRIO LabVIEW StartupApp manually start
Is it possible to close and re-open RTEXE through Embedded UI
(1,813 Views)
That's funny because with my RPI, if my LabVIEW app crashes, it's because something went sideways on the RPI and a reboot is absolutely necessary.
Bill
CLD
(Mid-Level minion.)
(1,789 Views)
