Restart a labview application using a .bat file
Thank you very much, but it is not opening since this uses labview higher version whereas mine is Labview 2012. Could you save your VI in labview 2012 and then post it again please. Thank you.
Message 11 of 14
(963 Views)
Accepted by govindsankar
Just saved to LabVIEW 2011.
Paolo
Message 12 of 14
(952 Views)
Thank you it works perfectly fine.
Message 13 of 14
(922 Views)
You should mark as a solution Paul Cardinale's post, since he is the author of the vi.
Paolo
Message 14 of 14
(917 Views)
