02-10-2012 12:50 PM
I have a customer trying to issue a restart command to a PXI-RT system from Labview 2011 64 bit. He says the command doesn't work.
I currently don't have 64bit so I can't test it very well right now.
Is this something anyone else has tried or experienced?
Josh
G Systems
Certified LabVIEW Architect
02-13-2012
01:39 PM
- last edited on
11-04-2025
12:37 PM
by
Content Cleaner
The real-time module is not supported for 64-bit LabVIEW. As a work around, you could install 32-bit LabVIEW onto your 64-bit OS. This should solve your customer's issue.
02-13-2012 01:42 PM
My customer is using very large data sets and has chosen 64 bit Labview because he has hit the memory constrains of 32 bit labview. Any other options?
Josh
02-13-2012
01:50 PM
- last edited on
11-04-2025
12:37 PM
by
Content Cleaner
If he/she needs to use RT, then 32-bit is his/her only option. Here is a very thorough tutorial on improving memory performance. Sometimes I admit it that memory constraints are unavoidable, but ideally this is not one of those scenarios.
