Restricting use of Ctrl.
Is there a way to restrict the use of control keys, especially ctrl-.,
in a LabView environment? The versions I'm most interested in are 5.1
and 6.1.
What I'd like to be able to do is tie control key usage to a given
access level, either in the LabView environment with something I program
or on a Window's user basis.
Ta...
Marty L. Williams
(2,486 Views)
Hi Marty,
The "ctrl ." is a short cut for the abort button. hide the Abort button under (in LV 6.1)
VI Properties>>>Windows Appearance>>>Customize>>>Show Abort Button
This property can also be manipulated programaticaly in LV 6.1 using a property node configured for
TB.ShowAbortBut
This will allow you to allow this operation for privledged users.
The same VI setting is available in LV 5.1 but I do not remeber if it could be manipulated programaticly.
Trying to help,
Ben
Ben Rayner
Certified LabVIEW Developer
www.D
SAutomation.com
(2,486 Views)
