Result getting displayed as Nan or 0 or 9.49353E-5 ?
Hello all,
In this app i am calculating total distance for the data base .  so i have find  the distance between two points . In this process..............If the distance to be  calculated between the two points are same means i.e x1 = x2 and y1 = y2 ..i am facing the below problem
In the below attached file the distance calculater vi is some time showing the result as zero and some times as Nan and some times as 9.49353E-5
But when i open the distace cal vi and run it individually but entering the same inputs which are passed to it , it is showing zero . but if i call it as a sub vi and read its value this is showing some times as nan or 9.49353E-5
Message 1 of 11
(3,627 Views)
Please attach your VI converted for an older LabVIEW version...
Message 2 of 11
(3,605 Views)
It is because floating point is not truely exact.  There are rounding errors from your calculations that could cause the results to be off by a bit or more.  This is true for any programming language.
Message 3 of 11
(3,604 Views)
Message 4 of 11
(3,596 Views)
Hello
What should i do to solve this problem
Message 5 of 11
(3,594 Views)
Hi Nagaa,
you should do some error checking before calculating that ACOS: you receive NaN when x is not between -1 and +1 for ACOS...
Hint:
There's a joint SIN/COS function, no need for two separate function calls...
Message 6 of 11
(3,591 Views)
hello
Please put your matter in a vi , i am not able to get you
Message 7 of 11
(3,573 Views)
Hi Nagaa,
maybe you get the point now:
Maybe reading some articles on that topic might help too 🙂
Message 8 of 11
(3,563 Views)
Right click on the indicator & select display format, then select floating point. Then make the precision type as digit of precision & in the digit section enter the digit for precision. If you want 2 digit precision then enter 2.
This NaN is actually not a number. Reason for this can be,
  • division of zero by zero
  • square root of a negative number
  • division of an infinity by an infinity
  • logarithm (any base) of a non-positive number
  • any calculation which includes NaN as one of its operands
Make sure this condition.
Hope this will help. for better help conver the vi to 2011 compatible. Will deal with it
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 9 of 11
(3,554 Views)
Hi Ranjeet,
one more reason for NaN is given in the context help for ACOS - and (I think) that would be the most reasonable here...
Message 10 of 11
(3,548 Views)
