Retrieving Data from JSON
Hi
I need to retrieve data from JSON using unflatten from JSON sub vi.
My JSON is {"LogMsg":[{"PE":128,"UID":"WISE-4012_00D0C9E2F3B5","TIM":"1573536496","Record":[[0, 0, 7, 10],[0, 0,11, 0]]}]}
I need the value 7 from it.
I want a method without using any addons
Message 1 of 9
(5,538 Views)
Accepted by topic author tomp93
How about:regex.png
Certified LabVIEW Architect
Message 2 of 9
(5,523 Views)
I'm no power user of JSON, but if you really want to use the unflatten from JSON, you can do it like this:
I tried using "path" down to "record" but that doesn't work, not sure why, or how that path should be constructed.
Message 3 of 9
(5,501 Views)
Thanks ... 🙂
It Worked. Now Iwant solution to get that timestamp "1573536496" from that.
Could you please suggest similar for that also.
Message 4 of 9
(5,497 Views)
Here is another one if you really only want 7:
Message 5 of 9
(5,495 Views)
Thanks cordm, thats where I was failing. Of course it should be like that.
Message 6 of 9
(5,485 Views)
@tomp93 wrote:
Thanks ... 🙂
I suggest you go to https://regex101.com and test the regex for that by some trial end error. Thats what I always do.
Message 7 of 9
(5,482 Views)
@tomp93 wrote:
Thanks ... 🙂
What date should 1573536496 be? There are a few different standards...
Anyway, unbundle the string, and parse the string. It's not a JSON problem anymore.
Message 8 of 9
(5,480 Views)
Thank you all for the solutions. All worked. 🙂
Message 9 of 9
(5,446 Views)
