Retrieving a SMS message from a bluetooth device
Lets see if anybody has tried this one. I'm using LV 7.1 PocketPC 2003 and want to retrieve a SMS message from a Bluetooth cellphone into my PDA. I see there are necessary VIs in order to connect via Bluetooth, but how do I get the SMS messages from the cellphone?
(2,635 Views)
I have done that some time ago, so many things can be changed. Basically you communicate tith you phone over the AT commands, sending the ASCI command string proper for your phone (see phone manual). As an anwer you will get the string with your SMS message.
cheers
Pawel
(2,627 Views)
