06-28-2007 06:05 PM
06-29-2007 01:12 AM
Hi David,
I think it will be easier to help if you could post your code. Also, I'm assuming you're using DAQmx and LV 7.1 or above. Finally, there is a dedicated hardware board for counters/timers. You should always try to post to the most appropriate board and I would encourage you to repost your original question to that board along with the suggestions I've provided.
Caz
